Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 20
Continue peeling up the tape away until there is enough slack in the left speaker cable to disconnect it. Do not completely remove the tape—it will be easier to replace if you leave a section still attached to the rear case.
  • Continue peeling up the tape away until there is enough slack in the left speaker cable to disconnect it.
  • Do not completely remove the tape—it will be easier to replace if you leave a section still attached to the rear case.
Insertar traducción aquí
