Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 6
Be careful when flipping up the logic board. The headphone jack and docking port are attached to the board. Gently lift the logic board (and attached components) upward. The smaller portion of the logic board that resides underneath is very bendable and frail. Make sure not to pull the spudger upward when using it to detach the small board. Use only side-to-side movement.
  • Be careful when flipping up the logic board. The headphone jack and docking port are attached to the board.
  • Gently lift the logic board (and attached components) upward.
  • The smaller portion of the logic board that resides underneath is very bendable and frail. Make sure not to pull the spudger upward when using it to detach the small board. Use only side-to-side movement.
  • Slide the spudger under the small portion of the logic board. The board should come loose once the spudger has slid almost all the way to the other side.
Insertar traducción aquí
