Saltar al contenido principal
Inglés
Español
Paso 2
Start removing the front bezel in the lower display corners using a prying tool. Make sure the glue and tape will stick to the front bezel instead of the display and rear bezel. You can use a gripping tool and a cutter for this. Make sure the glue and tape will stick to the front bezel instead of the display and rear bezel. You can use a gripping tool and a cutter for this.
Remove Front Bezel
  • Start removing the front bezel in the lower display corners using a prying tool.
  • Make sure the glue and tape will stick to the front bezel instead of the display and rear bezel. You can use a gripping tool and a cutter for this.
Insertar traducción aquí
