Saltar al contenido principal
Inglés
Español
Paso 11
Finish tightening the oil drain plug with a 13 mm socket wrench. Only tighten the drain plug until it is snug. Over-tightening the oil drain plug can strip or crack the oil pan—a very costly error. You can always tighten the drain plug more later. Wipe off the area around the drain plug one more time with a rag or towel.
  • Finish tightening the oil drain plug with a 13 mm socket wrench.
  • Only tighten the drain plug until it is snug. Over-tightening the oil drain plug can strip or crack the oil pan—a very costly error. You can always tighten the drain plug more later.
  • Wipe off the area around the drain plug one more time with a rag or towel.
Insertar traducción aquí
