Saltar al contenido principal
Inglés
Español
Paso 3
Slide a 13 mm socket over the oil drain plug. Use a ratcheting socket wrench to loosen the oil drain plug to the point that you can remove it with your fingers. Use a ratcheting socket wrench to loosen the oil drain plug to the point that you can remove it with your fingers.
  • Slide a 13 mm socket over the oil drain plug.
  • Use a ratcheting socket wrench to loosen the oil drain plug to the point that you can remove it with your fingers.
Insertar traducción aquí
