Inglés
Español
Paso 8
The oil filter is a small cylinder, about 2.5" in diameter, located on the right side of the engine underneath the intake manifold. Hold a rag or towel underneath the oil filter and grab the filter with your hand. The rag will be used to catch any leaking oil when removing the filter
  • The oil filter is a small cylinder, about 2.5" in diameter, located on the right side of the engine underneath the intake manifold.
  • Hold a rag or towel underneath the oil filter and grab the filter with your hand. The rag will be used to catch any leaking oil when removing the filter
  • Loosen the oil filter by twisting it counterclockwise.
  • You may have to use an oil filter wrench if the filter is on too tight. There is very limited space next to the engine, though, so a wrench that fits over the top of the filter is ideal.
Insertar traducción aquí
