Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 5
When the drain plug is completely loose, let it fall into the oil drain pan with the draining oil. Avoid letting the plug fall if you have an "homemade" pan. However, there is no problem with an oil drain pan off the shelf. Watch the draining oil for shiny specks. Metal flakes in the oil could mean that there is a serious problem with your engine internals.
  • When the drain plug is completely loose, let it fall into the oil drain pan with the draining oil.
  • Avoid letting the plug fall if you have an "homemade" pan. However, there is no problem with an oil drain pan off the shelf.
  • Watch the draining oil for shiny specks. Metal flakes in the oil could mean that there is a serious problem with your engine internals.
  • Allow oil to drain out of the oil pan until it slows to small drops.
  • Once the draining has slowed significantly, wipe off the area around the oil drain with a rag or towel.
  • Replace the drain plug and hand-tighten it.
  • It is better to put a seal under the drain plug (outside diameter 20 mm, inside diameter 15 mm).
Insertar traducción aquí
