Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 4
Always wear protective gloves and eyewear when working with motor oil. Be careful if your car has been running recently, since the engine and transmission will be very hot. Keep rags or towels nearby to wipe up any spills. Use a 19 mm box end wrench or socket wrench to loosen the oil drain plug.
  • Always wear protective gloves and eyewear when working with motor oil. Be careful if your car has been running recently, since the engine and transmission will be very hot. Keep rags or towels nearby to wipe up any spills.
  • Use a 19 mm box end wrench or socket wrench to loosen the oil drain plug.
  • After a few full turns with the wrench, use your fingers to loosen the oil drain plug.
Insertar traducción aquí
