Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 8
Continue flushing the brake lines as described above until you see the new brake fluid coming through the bleed tube. The new brake fluid will be a lighter color than the old, discolored brake fluid. Keep an eye on the master cylinder. If the fluid level gets too low again, be sure to add more fluid.
  • Continue flushing the brake lines as described above until you see the new brake fluid coming through the bleed tube.
  • The new brake fluid will be a lighter color than the old, discolored brake fluid.
  • Keep an eye on the master cylinder. If the fluid level gets too low again, be sure to add more fluid.
  • When you are seeing new brake fluid coming through the bleed hose, stop the flushing process and firmly close the bleed valve.
  • Gently pull the bleed tube off of the bleed valve and re-cover the valve with the little rubber cap.
Insertar traducción aquí
