Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Inglés
Español
Paso 6
Using a 3/8" wrench with your left hand, open the bleed valve on the front brake cylinder. The built-up pressure in the lines will force some of the brake fluid out of the lines. Continue to force more brake fluid out of the brake lines by depressing the front brake lever with your right hand.
  • Using a 3/8" wrench with your left hand, open the bleed valve on the front brake cylinder.
  • The built-up pressure in the lines will force some of the brake fluid out of the lines.
  • Continue to force more brake fluid out of the brake lines by depressing the front brake lever with your right hand.
  • While bleeding the brakes, focus on the bleeder hose. If you see an air bubble traveling up the bleed hose, close the bleed valve immediately, and begin the process again.
  • Once the brake lever is completely depressed, quickly close the bleed valve, making sure that no air bubbles enter into the brake lines.
Insertar traducción aquí
