Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Inglés
Español
Paso 5
Before proceeding, read all the way through steps five and six to make sure that you completely understand the actions for bleeding the brake lines. Carefully pump the brake lever a few times to build up pressure in the brake lines. In the next step, you will release the fluid from the brake lines by opening the bleed valve at the bottom of the lines and simultaneously squeezing the brake lever.
Flushing the brake line
  • Before proceeding, read all the way through steps five and six to make sure that you completely understand the actions for bleeding the brake lines.
  • Carefully pump the brake lever a few times to build up pressure in the brake lines.
  • In the next step, you will release the fluid from the brake lines by opening the bleed valve at the bottom of the lines and simultaneously squeezing the brake lever.
Insertar traducción aquí
