Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Inglés
Español
Paso 3
Locate the brake fluid bleed valve on the top of the front brake assembly, and flip up the rubber cap covering it. Slide a 3/8" brake bleeder hose over the bleed valve. If you are using a stop valve for bleeding the brake lines, make sure that the arrow on the valve is pointing away from the brake assembly (along the direction of flow).
  • Locate the brake fluid bleed valve on the top of the front brake assembly, and flip up the rubber cap covering it.
  • Slide a 3/8" brake bleeder hose over the bleed valve.
  • If you are using a stop valve for bleeding the brake lines, make sure that the arrow on the valve is pointing away from the brake assembly (along the direction of flow).
Insertar traducción aquí
