Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 13 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Use the flat end of a spudger to lift the I/O board connector up and out of its socket on the logic board Be sure to lift straight up on the connector as you disconnect it from its socket. The socket is very deep on the logic board and prying it from side to side may damage the logic board
  • Use the flat end of a spudger to lift the I/O board connector up and out of its socket on the logic board
  • Be sure to lift straight up on the connector as you disconnect it from its socket. The socket is very deep on the logic board and prying it from side to side may damage the logic board
  • Remove the I/O board cable.
Insertar traducción aquí
