Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Paso 6
Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket. Remove the small rubber gasket from the corner of the upper case near the display data cable. Remove the small rubber gasket from the corner of the upper case near the display data cable.
  • Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
  • Remove the small rubber gasket from the corner of the upper case near the display data cable.
Insertar traducción aquí
