Saltar al contenido principal
Inglés
Español
Paso 4
Holding the brake assembly in one hand and the floating caliper in the other, gently slide the floating caliper into the front brake assembly. The anti-squeal side of the brake pad should be facing away from the stationary caliper, and towards the brake piston. Move the floating caliper alignment peg so that the metal tab on the floating caliper fits together with the indentation on the alignment peg.
  • Holding the brake assembly in one hand and the floating caliper in the other, gently slide the floating caliper into the front brake assembly.
  • The anti-squeal side of the brake pad should be facing away from the stationary caliper, and towards the brake piston.
  • Move the floating caliper alignment peg so that the metal tab on the floating caliper fits together with the indentation on the alignment peg.
Insertar traducción aquí
