Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 9
Using a Phillips #2 screwdriver, remove the two screws securing the cover on the master brake-fluid reservoir. Carefully remove the cover of the master reservoir, making sure that you do not spill any of the  brake fluid. Brake fluid can cause ugly stains and scarring on cosmetic components of the motorcycle. Make sure you don't spill any.
Depressing the brake piston
  • Using a Phillips #2 screwdriver, remove the two screws securing the cover on the master brake-fluid reservoir.
  • Carefully remove the cover of the master reservoir, making sure that you do not spill any of the brake fluid.
  • Brake fluid can cause ugly stains and scarring on cosmetic components of the motorcycle. Make sure you don't spill any.
Insertar traducción aquí
