Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 28 guías que incluyan este paso.
Inglés
Español
Paso 5
The display data cable plug has a wire lock.  Disengage the plug's lock by rotating the plastic tab so that it points upward.  (It is not a pull tab.) Pull the display data cable straight out of its socket on the logic board.
  • The display data cable plug has a wire lock. Disengage the plug's lock by rotating the plastic tab so that it points upward. (It is not a pull tab.)
  • Pull the display data cable straight out of its socket on the logic board.
  • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
Insertar traducción aquí
