Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Paso 5
Use a plastic opening tool to wedge between the screen and the device, while simultaneously holding the clip open from step 4. Pry the screen very gently to avoid cracking the glass Start to remove the screen from where the black plastic trim was removed and work the tool around the sides of the device. You will here small pops from the clips on the sides being released.
  • Use a plastic opening tool to wedge between the screen and the device, while simultaneously holding the clip open from step 4.
  • Pry the screen very gently to avoid cracking the glass
  • Start to remove the screen from where the black plastic trim was removed and work the tool around the sides of the device. You will here small pops from the clips on the sides being released.
  • The Amazon Fire can now be opened with the two flex cables at the base still connected
Insertar traducción aquí
