Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Ensure that the device is turned off. Holding the device firmly, wedge a plastic opening tool between the  speaker cover and the device. Then pry up to separate it from the device. Then begin to firmly pry up the plastic cover with the plastic opening tool.
  • Ensure that the device is turned off.
  • Holding the device firmly, wedge a plastic opening tool between the speaker cover and the device. Then pry up to separate it from the device.
  • Then begin to firmly pry up the plastic cover with the plastic opening tool.
  • The backing is connected with adhesive so force may be necessary.
  • Be careful to not damage the plastic in any way.
  • Once you can fit your finger under the plastic cover, begin to slide your finger down the cover while simultaneously prying up.
Insertar traducción aquí
