Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 9
Remove the following five Phillips screws: Two 2.5 mm screws set into the left edge of the rear case
  • Remove the following five Phillips screws:
  • Two 2.5 mm screws set into the left edge of the rear case
  • One 2.1 mm Phillips #000 screw set into the left edge of the rear case
  • Two 2.1 mm screws set into the right edge of the rear case
  • If you overtighten these screws during reassembly, your power and volume buttons may not click properly. Check the clicking action on each button before you continue with reassembly.
Insertar traducción aquí
