Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 6 guías que incluyan este paso.
Inglés
Español
Paso 2
Use the point of a spudger to lift up and disconnect the Lightning connector ribbon cable from its socket on the logic board. Use the point of a spudger to lift up and disconnect the Lightning connector ribbon cable from its socket on the logic board.
  • Use the point of a spudger to lift up and disconnect the Lightning connector ribbon cable from its socket on the logic board.
Usa la punta de un spudger para levantar y desconectar la tira del cable del conector Lightning de su zócalo en la placa lógica.
