Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 6
Insert the flat end of a spudger between the Lightning connector assembly and rear case to break up the remaining adhesive. Insert the flat end of a spudger between the Lightning connector assembly and rear case to break up the remaining adhesive. Insert the flat end of a spudger between the Lightning connector assembly and rear case to break up the remaining adhesive.
  • Insert the flat end of a spudger between the Lightning connector assembly and rear case to break up the remaining adhesive.
Inserta el extremo plano de un spudger entre el ensamblaje del conector Lightning y la caja trasera para romper el adhesivo restante.
