Saltar al contenido principal
Inglés
Español
Traduciendo paso 9
Paso 9
Remove the Lightning connector assembly. If your replacement part does not come with a gasket, use tweezers to remove it from the old part and transfer it onto the replacement part. Before installing or replacing the Lightning connector assembly, use a plastic tool to scour any bits of adhesive residue from the rear case behind the cable.
  • Remove the Lightning connector assembly.
  • If your replacement part does not come with a gasket, use tweezers to remove it from the old part and transfer it onto the replacement part.
  • Before installing or replacing the Lightning connector assembly, use a plastic tool to scour any bits of adhesive residue from the rear case behind the cable.
Quita el ensamblaje del conector Lightning.
Si tu pieza de recambio no trae una junta de goma, usa unas pinzas para quitarla de la pieza antigua y ponla en la pieza nueva.
Antes de instalar o reemplazar el ensamblaje del conector Lightning, usa una herramienta de plástico para eliminar cualquier resto de residuo adhesivo de la carcasa trasera detrás del cable.
