Saltar al contenido principal
Inglés
Español
Paso 5
Insert a plastic opening pick between the edge of the rear case and the Lightning connector flex cable. Press the pick underneath the flex cable to break up the adhesive holding it in place. Press the pick underneath the flex cable to break up the adhesive holding it in place.
  • Insert a plastic opening pick between the edge of the rear case and the Lightning connector flex cable.
  • Press the pick underneath the flex cable to break up the adhesive holding it in place.
Insertar una púa de apertura de plástico entre el borde de la caja trasera y el cable flexible.
Presiona suavemente la púa por debajo del cable flexible para romper el adhesivo que lo sujeta en su lugar.
