Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 2
The metal cap does not require unscrewing and should lift up with ease. Unscrew all the screws that outline the perimeter of the board using a Phillips Head (PH1) screwdriver. Remove the silver shielding plate once all screws are removed. Be careful when pulling it under the affixed antenna cables.
  • The metal cap does not require unscrewing and should lift up with ease.
  • Unscrew all the screws that outline the perimeter of the board using a Phillips Head (PH1) screwdriver.
  • Remove the silver shielding plate once all screws are removed. Be careful when pulling it under the affixed antenna cables.
Insertar traducción aquí
