Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 2
Using a 5/32 Hex or Allen screwdriver, unscrew the two screws from the primary chain inspection cover. Your inspection cover may not be round, depending on the year. However, it will be in the same location and secured by similar screws. Remove the primary chain inspection cover from the transmission housing.
Removing the Primary Chain Inspection Cover
  • Using a 5/32 Hex or Allen screwdriver, unscrew the two screws from the primary chain inspection cover.
  • Your inspection cover may not be round, depending on the year. However, it will be in the same location and secured by similar screws.
  • Remove the primary chain inspection cover from the transmission housing.
Con un destornillador hexagonal 5/32 o Allen, desatornilla los dos tornillos de la cubierta de inspección de la cadena primaria.
Tu tapa de inspección puede no ser redonda, dependiendo del año. Sin embargo, estará en la misma ubicación y asegurado con tornillos similares.
Quita la cubierta de inspección de la cadena primaria de la caja de la transmisión.
