Saltar al contenido principal
Inglés
Español
Paso 4
Always inspect your new spark plugs before installing. Check the gap on your replacement spark plugs with a feeler gauge. It should be set to .040 inches. If they are not pre-installed, make sure that the crush washer and terminal nut are installed. If they are not pre-installed, make sure that the crush washer and terminal nut are installed.
Checking the new spark plug
  • Always inspect your new spark plugs before installing. Check the gap on your replacement spark plugs with a feeler gauge. It should be set to .040 inches.
  • If they are not pre-installed, make sure that the crush washer and terminal nut are installed.
Insertar traducción aquí
