Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 6
Move the drain pan back underneath the oil drain tube. By this time more oil will have collected in it. Remove the tube again, and allow it to run out until it is just a light drip. Reinstall the oil drain tube on its nipple, tightening the hose clamp with a flathead Screwdriver.
Re-installing the Drain Tube
  • Move the drain pan back underneath the oil drain tube. By this time more oil will have collected in it. Remove the tube again, and allow it to run out until it is just a light drip.
  • Reinstall the oil drain tube on its nipple, tightening the hose clamp with a flathead Screwdriver.
Mueve el contenedor de aceite viejo debajo del tubo de drenaje.En este punto, más aceite se habrá acumulado aquí. Retira el tubo de nuevo y deja que salga hasta que solo se derramen gotitas.
Vuelve a instalar el tubo y aprieta la brida con un destornillador plano.
