Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 6 guías que incluyan este paso.
Inglés
Español
Paso 3
If you are following this guide to replace the Lightning connector, you can choose to keep the antenna cable connected and skip this step and the next one. Be very careful not to strain the delicate antenna cable when you move the loudspeaker around. Use the point of a spudger to lift and disconnect the antenna cable from its socket near the top of the logic board.
  • If you are following this guide to replace the Lightning connector, you can choose to keep the antenna cable connected and skip this step and the next one. Be very careful not to strain the delicate antenna cable when you move the loudspeaker around.
  • Use the point of a spudger to lift and disconnect the antenna cable from its socket near the top of the logic board.
Si estas siguiendo esta guía para reemplazar el conector Lightning, puedes elegir mantener el cable de la antena conectado y saltarte los dos pasos siguientes. Ten mucho cuidado para no deformar el cable de la antena cuando muevas el altavoz.
Usa la punta de un spudger para levantar y desconectar el cable de la antena de su zócalo cerca de la parte de arriba de la placa lógica.
[* icon_note] If you are following this guide to replace the Lightning connector, you can choose to keep the antenna cable connected and skip this step and the next two stepsone. Be very careful not to strain the delicate antenna cable when you move the loudspeaker around.
[* black] Use the point of a spudger to lift and disconnect the antenna cable from its socket near the top of the logic board.
