Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 6 guías que incluyan este paso.
Inglés
Español
Paso 5
Remove the following Phillips screws securing the speaker to the rear case:
  • Remove the following Phillips screws securing the speaker to the rear case:
  • Two 2.6 mm screws
  • One 2.3 mm screw
  • This screw may be covered by some tape.
  • One 2.3 mm screw
  • This screw is different from the prior one. Be sure not to mix the two together.
  • One 3.0 mm screw
Quita los siguientes tornillos Philips que sujetan el altavoz a la carcasa trasera.
Dos tornillos de 2.6 mm
Un tornillo de 2.3 mm
Este tornillo es diferente del anterior. Asegúrate de no mezclarlos juntos
Un tornillo de 3.0 mm
[* black] Remove the following Phillips screws securing the speaker to the rear case:
[* red] Two 2.6 mm screws
[* orange] One 2.3 mm screw
[* icon_note] This screw may be covered by some tape.
[* yellow] One 2.3 mm screw
[* icon_note] This screw is different from the prior one. Be sure not to mix the two together.
[* green] One 3.0 mm screw
