Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 24 guías que incluyan este paso.
Inglés
Español
Paso 3
Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board. Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board. Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board.
  • Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board.
Usa la punta de un spudger para desconectar el conector de la batería haciendo palanca hacia arriba de la placa lógica .
