Saltar al contenido principal
Inglés
Holandés
Paso 8
To remove the hard drive, unscrew the two small Phillips screws holding the black plastic hard drive bracket to the chassis.  Pull up on the white plastic tab and lift the hard drive out of the case, being careful not to strain the SATA cable. Carefully disconnect the Serial ATA cable. Carefully disconnect the Serial ATA cable.
  • To remove the hard drive, unscrew the two small Phillips screws holding the black plastic hard drive bracket to the chassis. Pull up on the white plastic tab and lift the hard drive out of the case, being careful not to strain the SATA cable.
  • Carefully disconnect the Serial ATA cable.
Insertar traducción aquí
