Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Once you have removed the bottom cover you should have clear access to the music player.
  • Once you have removed the bottom cover you should have clear access to the music player.
  • Locate the music player and check to see if it is visibly dirty or clogged.
  • If there is any amount of dust or dirt on the music player it should be cleaned.
  • Using the straw that comes with your air duster, aim the duster in a way that the air will push the dust away from the music player.
  • If cleaning the music player is not enough, you may need to refer to the Music Player Replacement Guide
Insertar traducción aquí
