Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 7
Paso 7
Lift the flange upward and off to the side of the machine.
  • Lift the flange upward and off to the side of the machine.
  • There is enough wire connecting the flange to the machine that you will not need to cut the wire. The flange can be moved off to the side of the machine while you are working.
  • Cutting or ripping out the wire will cause damage to the machine so try not to put much tension on the wire.
Insertar traducción aquí
