Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 5
Paso 5
Use the flat end of a spudger to lift the battery out of the midframe. Check to make sure no ribbon cables remain stuck to the battery, and separate them carefully if needed. If there is still adhesive holding the battery down, slowly pry the battery away from the midframe, taking care not to bend the battery.
  • Use the flat end of a spudger to lift the battery out of the midframe.
  • Check to make sure no ribbon cables remain stuck to the battery, and separate them carefully if needed.
  • If there is still adhesive holding the battery down, slowly pry the battery away from the midframe, taking care not to bend the battery.
  • The battery will separate more easily if you add a few drops of isopropyl alcohol along each side, to soften the adhesive beneath. High concentration (90% or greater) alcohol will not harm your phone's components.
  • Alternatively, you may apply heat to the midframe to soften the battery adhesive, but be very careful not to overheat the battery.
  • Don't deform or puncture the battery—it can catch fire and/or explode if damaged.
  • Never reinstall a damaged or deformed battery. Replace the battery.
  • Use a few strips of thin double-sided adhesive tape, such as Tesa 61395 or strips from a pre-cut adhesive card, to secure the replacement battery.
Usa el extremo plano de un spudger para levantar la batería fuera del marco intermedio.
Asegúrate de que no queden atascados cables de cinta en la batería y sepáralos con cuidado si es necesario.
Si todavía hay adhesivo que sujeta la batería hacia abajo, tira lentamente de la batería hacia afuera del marco intermedio, teniendo cuidado de no doblarla.
La batería se separará más fácilmente si agrega unas gotas de alcohol isopropílico a lo largo de cada lado, para suavizar el adhesivo a continuación. El alcohol de alta concentración (90% o más) no dañará los componentes de tu teléfono.
Alternativamente, puedes aplicar calor a la parte media del marco para ablandar el adhesivo de la batería, pero tenga mucho cuidado de no sobrecalentar la batería.
No deformes ni perfores la batería; puede incendiarse y/o explotar si está dañada.
Nunca reinstales una batería dañada o deformada. Reemplaza la batería.
Use unas cuantas tiras de cinta adhesiva de doble cara delgada, como Tesa 61395 o tiras de una tarjeta adhesiva precortada, ]para asegurar la batería de reemplazo.
