Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 4
Slide an opening pick under the NFC connector to remove it from the battery. Note the position of the NFC connector, as it will need to be reinstalled in the same position on the replacement battery. If its existing adhesive is no longer sticky, you can remove that and use a high-bond double-sided tape, such as Tesa 61395.
  • Slide an opening pick under the NFC connector to remove it from the battery.
  • Note the position of the NFC connector, as it will need to be reinstalled in the same position on the replacement battery. If its existing adhesive is no longer sticky, you can remove that and use a high-bond double-sided tape, such as Tesa 61395.
Desliza la púa de apertura debajo del conector NFC para removerla de la batería.
Ten en cuenta la posición del conector NFC, ya que será necesario reinstalarlo en la misma posición en la batería de reemplazo. Si tu adhesivo existente ya no es pegajoso, puede quitarlo y usar una cinta de doble cara de alta adherencia, como Tesa 61395.
