Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 3
Hold a pair of pointed tweezers closed, and insert them into the small hole on the edge of the back cover near the SIM card slot. Use the tweezers to lift the cover up slightly, and slide an opening pick into the gap between the cover and the frame. Use the tweezers to lift the cover up slightly, and slide an opening pick into the gap between the cover and the frame.
  • Hold a pair of pointed tweezers closed, and insert them into the small hole on the edge of the back cover near the SIM card slot.
  • Use the tweezers to lift the cover up slightly, and slide an opening pick into the gap between the cover and the frame.
Sostén un par de pinzas puntiagudas cerradas e insértalas en el pequeño orificio en el borde de la tapa trasera cerca de la ranura para la tarjeta SIM.
Usa las pinzas para levantar la tapa ligeramente y desliza la púa de apertura en el espacio entre la tapa y el marco.
