Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
Try to keep the adhesive strips flat and unwrinkled during this procedure; twisted or wrinkled strips will stick together and break instead of pulling out cleanly. Additionally, do not press down on the battery as you pull the strips. Pressing on the battery creates pressure points that can snag and break the adhesive. Grasp one of the battery adhesive tabs with your fingers and slowly pull it away from the battery, towards the bottom of the phone.
  • Try to keep the adhesive strips flat and unwrinkled during this procedure; twisted or wrinkled strips will stick together and break instead of pulling out cleanly.
  • Additionally, do not press down on the battery as you pull the strips. Pressing on the battery creates pressure points that can snag and break the adhesive.
  • Grasp one of the battery adhesive tabs with your fingers and slowly pull it away from the battery, towards the bottom of the phone.
  • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the midframe. For best results, pull the strip at as low an angle as possible, without snagging it on any other components.
  • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
  • If the battery adhesive tabs break during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
  • If any of the adhesive strips break underneath the battery and cannot be retrieved, try to remove the remaining strip, and then proceed with the rest of the steps.
Trata de mantener las tiras adhesivas planas y sin arrugas durante este procedimiento. Las cintas dobladas o arrugadas se pegarán y romperán en vez de salir fácilmente.
Adicionalmente, no presiones en la batería mientras tiras de las tiras. Presionar la batería crea puntos de presión que pueden engancharse y romper el adhesivo.
Toma una de las lengüetas adhesivas de la batería con tus dedos y despacio apártala de la batería tirando haca la parte inferior del teléfono.
Tira de manera constante, manteniendo una tensión constante en la tira hasta que se deslice hacia afuera entre la batería y el marco central. Para obtener los mejores resultados, tira de la tira en el ángulo más bajo posible, sin engancharla en ningún otro componente.
La tira se estirará muchas veces su longitud original. Continua tirando y vuelve a agarrar la tira cerca de la batería si es necesario.
Si las lengüetas adhesivas de la batería se rompen durante el proceso de extracción, utiliza los dedos o las pinzas sin filo para recuperar la longitud restante del adhesivo y continua tirando.
Si alguna de las tiras adhesivas se rompe debajo de la batería y no se puede recuperar, intenta quitar la tira restante y luego continua con el resto de los pasos.
