Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Ensure that the device is turned off before beginning. Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point. Be careful if using the metal spudger, as it can scratch the surface of the Kindle.
  • Ensure that the device is turned off before beginning.
  • Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point.
  • Be careful if using the metal spudger, as it can scratch the surface of the Kindle.
Insertar traducción aquí
