Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Once all cables have been disconnected from the motherboard, remove the seven remaining 3.0 mm screws with a Phillips head screwdriver size #00. After the screws have been removed lift up on the motherboard to remove it from the case.
  • Once all cables have been disconnected from the motherboard, remove the seven remaining 3.0 mm screws with a Phillips head screwdriver size #00.
  • After the screws have been removed lift up on the motherboard to remove it from the case.
  • If you feel any pull when removing the motherboard, check to see if you did not disconnect a cable connected to the board.
Insertar traducción aquí
