Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Paso 3
Once the 4 screws have been removed use the plastic opening tool to pry open the device on the side of the device. Be careful prying on the sides where you removed the screw as the plastic casing is not very strong and may break.
  • Once the 4 screws have been removed use the plastic opening tool to pry open the device on the side of the device.
  • Be careful prying on the sides where you removed the screw as the plastic casing is not very strong and may break.
  • After prying open the case with the plastic opening tool carefully remove the case from the device and place the device face down on its screen.
Insertar traducción aquí
