Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Holandés
Paso 2
Remove the following two screws: One 3.3 mm Phillips screw One 2.1 mm Phillips screw
  • Remove the following two screws:
  • One 3.3 mm Phillips screw
  • One 2.1 mm Phillips screw
  • Lift the metal retainer clip straight up from its recess in the rear panel.
  • If the camera comes up with the retaining clip, don't worry. Just separate the camera from the clip before reinstalling, so you can be sure to get the connector in the right place.
  • Be sure the small thermal pad is attached to the metal retaining clip as seen in the third picture when replacing the rear camera.
Insertar traducción aquí
