Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Carefully lay the LCD next to the rear panel. Use a plastic opening tool to lift the display data cable lock upwards. Pull the display data cable out of its socket.
  • Carefully lay the LCD next to the rear panel.
  • Use a plastic opening tool to lift the display data cable lock upwards.
  • Pull the display data cable out of its socket.
  • Do not pull the connector upward as you disconnect it from its socket.
Insertar traducción aquí
