Inglés
Español
Paso 2
Use the edge of a plastic opening tool to carefully pry the dock connector cable's connector up from its socket on the logic board. Peel the dock connector ribbon cable off the rear panel.
  • Use the edge of a plastic opening tool to carefully pry the dock connector cable's connector up from its socket on the logic board.
  • Peel the dock connector ribbon cable off the rear panel.
  • Do not try to completely remove the cable, as it is still securely attached to the rear panel.
Insertar traducción aquí
