Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 153 guías que incluyan este paso.
Inglés
Español
Paso 15
Continue releasing the adhesive along the bottom of the iPad, pulling the opening pick out far enough to go around the home button, and re-inserting it to a depth of 1/2 inch (10 mm) once the pick is past the home button. If the adhesive has cooled too much along the bottom edge, reheat the iOpener to warm the adhesive where you are working. Do not heat the iOpener more than a minute at a time, and always allow at least two minutes before reheating it.
  • Continue releasing the adhesive along the bottom of the iPad, pulling the opening pick out far enough to go around the home button, and re-inserting it to a depth of 1/2 inch (10 mm) once the pick is past the home button.
  • If the adhesive has cooled too much along the bottom edge, reheat the iOpener to warm the adhesive where you are working.
  • Do not heat the iOpener more than a minute at a time, and always allow at least two minutes before reheating it.
Continúe soltando el adhesivo a lo largo de la parte inferior del iPad, tirando de la selección de apertura lo suficiente para rodear el botón de inicio, y volver a insertarlo a una profundidad de 1/2 pulgada una vez que la selección está pasado el botón de inicio.
Si el adhesivo se ha enfriado demasiado a lo largo del borde inferior, recaliente el iOpener para calentar el adhesivo donde está trabajando.
No caliente el iOpener más de un minuto a la vez, y siempre deje al menos dos minutos antes de recalentarlo.
[* black] Continue releasing the adhesive along the bottom of the iPad, pulling the opening pick out far enough to go around the home button, and re-inserting it to a depth of 1/2 inch (10 mm) once the pick is past the home button.
[* icon_note] If the adhesive has cooled too much along the bottom edge, reheat the iOpener to warm the adhesive where you are working.
[* icon_caution] Do not heat the iOpener more than a minute at a time, and always allow at least two minutes before reheating it.
