Saltar al contenido principal
Inglés
Español
Paso 17
If you removed the wheel bearing with the brake drum, reinstall the rear hub nut. Torque this nut to 175 ft-lbs. Failure to properly tighten this nut could lead to premature wheel bearing failure. Reinstall the wheel bearing dust cap.
  • If you removed the wheel bearing with the brake drum, reinstall the rear hub nut.
  • Torque this nut to 175 ft-lbs. Failure to properly tighten this nut could lead to premature wheel bearing failure.
  • Reinstall the wheel bearing dust cap.
  • If you removed the brake drum by itself, reinstall the four retaining bolts on the back of the hub assembly.
  • Torque each bolt to 49 ft-lbs.
Insertar traducción aquí
