Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 5
Pull the brake drum straight away from the hub assembly to remove it.
  • Pull the brake drum straight away from the hub assembly to remove it.
  • If the drum will not come off easily, make sure that the parking brake is not engaged.
  • If your Focus is equipped with ABS, you will need to disconnect the ABS connector before you can remove the brake drum.
Insertar traducción aquí
