Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 3
This step is for removing the brake drum and the wheel bearing together. Use a mallet and a flat head screwdriver to make a small indentation along the edge of the wheel bearing dust cap. Pry the dust cap out of the brake drum with the flat head screwdriver.
  • This step is for removing the brake drum and the wheel bearing together.
  • Use a mallet and a flat head screwdriver to make a small indentation along the edge of the wheel bearing dust cap.
  • Pry the dust cap out of the brake drum with the flat head screwdriver.
  • Remove the 29 mm rear hub bolt nut from the brake drum. This will require either a breaker bar or an impact wrench.
  • This nut is torqued to 175 ft-lbs, and should not be removed more than four times. Use a permanent marker to make a mark on the nut each time it is removed.
Insertar traducción aquí
