Traduciendo paso 2
Paso 2
If you are replacing the brake drums, then follow the appropriate directions for your replacement part: with or without the bearing installed. If you are not replacing the drums, keep in mind that the rear wheel hub bolt that holds the bearing in place must be torqued to 175 ft-lbs.
