Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Use a small iPod opening tool to flip up the brown plastic tab holding the orange hard drive ribbon in place. The brown tab will rotate up 90 degrees, releasing the ribbon cable. Slide the orange hard drive ribbon cable directly out of its connector. The cable may be attached to the logic board with some adhesive. If the cable doesn't immediately come free, carefully pull up on the cable to loosen the adhesive. Logic board remains.
  • Use a small iPod opening tool to flip up the brown plastic tab holding the orange hard drive ribbon in place. The brown tab will rotate up 90 degrees, releasing the ribbon cable.
  • Slide the orange hard drive ribbon cable directly out of its connector. The cable may be attached to the logic board with some adhesive. If the cable doesn't immediately come free, carefully pull up on the cable to loosen the adhesive.
  • Logic board remains.
Usa una pequeña espátula de apertura de plástico para abrir la pestaña marrón de plástico que sujeta al cable plano naranja del disco duro en su lugar. La pestaña marrón girará hasta 90 grados, liberando el cable.
Desliza el cable plano naranja directamente hacia afuera de su conector. El cable puede estar pegado a la tarjeta lógica con algo de pegamento. Si el cable no sale inmediatamente, con cuidado jálalo hacia arriba para aflojar el pegamento.
Quedará solamente la tarjeta lógica.
